Can a galaxy have a recession velocity greater than the speed of light?
In summary: This is due to the fact that they are moving away from us at speeds which are faster than the speed of light, but which are smaller than the speed of the cluster expansion.
nnxion
Hi all. I was reading: http://www.astro.ucla.edu/~wright/doppler.htm but I'm failing to understand this part:
When z is larger than 1 then cz is faster than the speed of light and, while recession velocities faster than light are allowed, this approximation using cz as the recession velocity of an object is no longer valid. Thus for the largest known redshift of z=6.3, the recession velocity is not 6.3*c = 1,890,000 km/sec. It is also not the 285,254 km/sec given by the special relativistic Doppler formula 1+z = sqrt((1+v/c)/(1-v/c)). The actual recession velocity for this object depends on the cosmological parameters, but for an OmegaM=0.3 vacuum-dominated flat model the velocity is 585,611 km/sec. This is faster than light.
My understanding is that a galaxy cannot move faster than c (the speed of light). Why then could a galaxy moving close to c have a recession velocity greater than the speed of light? What would happen to the value of redshift?
Astronomy news on Phys.org
I think that this is once again a case of mistaking the expansion of space-time for physical movement within the universe. The galaxies can recede relative to us at superluminal velocity because the amount of space between us is enlarging. They're not moving very fast in relation to the space-time that they're in.
Okay thanks for clearing that up. Another question then: When is the value of redhift largest? When a galaxy is receding faster than light? When does redshift get shifted to infinite wavelength? Does every object that's at a same distance from us (earth) have the same redshift?
The cosmological red shift of the light from an object observed today, where the scale factor is R(t0), which was emitted when the object was situated when the scale factor was R(te) is given by
[tex]1 + z = \frac{R(t_0)}{R(t_e)}[/tex]
so z tends to infinity as R(te) tends to zero, i.e. for an object at the Big Bang itself. The nearest we can actually get to observing the Big Bang directly is the Cosmic Microwave Background which is observed at a red shift of over 1000.
I hope this helps.
Garth
Objects at the same distance from Earth may have different redshifts caused by their respective peculiar motions through space (along the line of sight). For instance, galaxies orbiting within a cluster of galaxies show a distribution of redshifts that are well approximated by a Gaussian (assuming the cluster is relaxed, ie. not merging with another cluster), with the mean redshift approximately equal to the redshift due to cosmological expansion (ignoring the fact that the cluster as a whole may have some peculiar velocity along the line of sight).
Related to Can a galaxy have a recession velocity greater than the speed of light?
1. What is the Doppler effect?
The Doppler effect is the change in frequency or wavelength of a wave in relation to an observer who is moving relative to the source of the wave. It is commonly experienced with sound waves, such as the sound of a siren changing as an ambulance passes by.
2. How does the Doppler effect apply to light waves?
The Doppler effect can also apply to light waves, known as the Doppler shift. As an object emitting light moves towards or away from an observer, the wavelength of the light is compressed or stretched, causing a shift in the perceived color. This is used in astronomy to determine the speed and direction of celestial objects.
3. What causes the Doppler shift?
The Doppler shift is caused by the relative motion between the source of the wave and the observer. If the source is moving towards the observer, the waves will be compressed, resulting in a higher frequency and shorter wavelength. If the source is moving away from the observer, the waves will be stretched, resulting in a lower frequency and longer wavelength.
4. How is the Doppler shift used in different fields of science?
The Doppler shift has various applications in different fields of science, including astronomy, meteorology, and medicine. In astronomy, it is used to determine the speed and direction of celestial objects. In meteorology, it is used to track weather patterns and predict severe weather. In medicine, it is used in ultrasound imaging to measure blood flow and diagnose conditions.
5. Can the Doppler shift be observed with stationary sources?
No, the Doppler shift can only be observed when there is relative motion between the source of the wave and the observer. If both are stationary, there will be no change in frequency or wavelength. This is why the Doppler shift is commonly experienced with moving objects, such as emergency vehicles or stars in the sky.
  • Astronomy and Astrophysics
